Date/Time: Thu, 06 Mar 2025 12:58:12 +0000
Charts Data Feed?
View Count: 559
[2022-02-03 19:18:38] |
nvadlamudi - Posts: 2 |
My charts are not getting upto date data. I see lots of them just show until 10.15 am after that no feed some of them are around 15 minutes delayed Can you check and let me know why? |
[2022-02-03 20:15:09] |
John - SC Support - Posts: 38425 |
What markets do you need data for or want to trade? For example, what particular futures, Forex or stock symbols. You can also give us the exchanges that the particular symbol or symbols trade on. If you require real-time futures data, then refer to: https://www.sierrachart.com/index.php?page=doc/doc_FuturesData.php Be sure to read the page linked above completely before making a further inquiry regarding real-time *futures* data. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-02-04 02:31:51] |
Do only US exchange Stocks!! Please provide me access to those exchanges
[2022-02-04 11:42:21] |
You will want to use the NASDAQ data feed. This is documented here: How to Use New NASDAQ Total View Data Feed Make sure to use the correct symbols like AAPL-NQTV: Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-02-04 11:43:56
