Date/Time: Thu, 06 Mar 2025 13:53:10 +0000
there is not enough volume for shares during the day
View Count: 459
[2022-02-03 15:24:39]
Пользователь488020 - Posts: 100
Hello, I have a problem: there is not enough volume for shares during the day. I try to connect as a Sierra Chart - All services and connection to Interactive Brokers. The result is the same. The data in the history shows normally. There is a picture. What do you recommend?
imageqwestion to sch.jpg / V - Attached On 2022-02-03 15:24:29 UTC - Size: 80.71 KB - 124 views
[2022-02-03 15:34:12]
We are looking into this issue. And we will find out what the answer is. Whether it is correct or there is some issue we need to resolve.
[2022-02-03 16:10:20]
The answer was "is there life on Mars"? Ok, post information about the problem when the cause is resolved.
