Date/Time: Thu, 06 Mar 2025 14:11:12 +0000
Chartbook saving issues
View Count: 448
[2022-02-03 15:07:16]
Gfreeman - Posts: 1
I made several chartbooks and saved them, and I imported several as well and saved them with zero issues. The most recent chartbook I made was /NQ and when i try to save it a message will come up on the screen and the chartbook will not save. I have tried saving it a couple different ways and the same message comes up, and I have no clue what it's even saying
https://www.sierrachart.com/Download.php?Folder=TicketingSystem&download=60831
[2022-02-03 15:51:58]
John - SC Support - Posts: 38425
You can not use a "/" in a filename. That is the cause of this issue. Get rid of that "/" and you will be fine. There are other special characters that can not be used in a filename as well, so typically just avoid the special characters in a filename in general.
