Date/Time: Thu, 13 Mar 2025 07:53:09 +0000
Data feed
View Count: 711
[2022-02-03 15:06:48] |
Matt654 - Posts: 73 |
Can you tell me which data feed I should use to populate the buy and sell columns in the dom , i think I need market depth in order to do that, but I'm not sure. I currently have SC Data (CFDs) and have tried package 11 with Denali data but it still doesn't populate the dom fully. I only trade the US30 index so that could narrow it down a bit. Anyway could you point out my best options.
[2022-02-07 22:35:10] |
Use the Delayed Exchange Data Feed and the symbol YMH22-CBOT Refer to: Delayed Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-06-07 13:56:06] |
FXCM CFD Dow data coming through in fits and starts out of sync the last few days, saw your messages that it is down to FXCM. But its been a few days so registering the problem in writing. In the meantime I've stopped trading .
[2022-06-07 15:28:39] |
John - SC Support - Posts: 38621 |
We are watching the situation with the FXCM data and working on an alternative.
