Date/Time: Thu, 06 Mar 2025 13:47:53 +0000
Chart Values Window
View Count: 818
[2022-02-03 15:06:21] |
User862138 - Posts: 21 |
Is it possible to see the previous day Chart Values Window in order to get some data?
[2022-02-03 15:41:11] |
John - SC Support - Posts: 38425 |
There is a not a "Chart Values Window" that will show you the previous days information. But you can use the Tool Values Window and move the crosshairs to the appropriate bar to get the information you want. For instance, on a Daily chart, you would just go back one bar to see the previous day's information. Refer to the following: Chart Drawing Tools: Tool Values Window For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-02-03 16:12:24] |
Many thanks - I understand. I guess it is not possible to do the same with a Numbers Bars Chart (Market Profile chart) - to see the data for the previous day session?
[2022-02-03 17:03:27] |
For the TPO profiles (Market Profile), you have the option of using the Single Profile Start Date-Time and Single Profile End Date-Time, so you could create a profile just for a single day of any particular day. Refer to the information here: Time Price Opportunity (TPO) Profile Charts: Single Profile Start Date-Time But, if you have multiple profiles, or you are using the Numbers Bars, you would have to use the Tool Values Window in the same way as with bar data, where you move the crosshair to the time you want to view the data for that period/bar. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-02-03 17:03:39
