Date/Time: Thu, 06 Mar 2025 16:34:56 +0000
Aud/jpy CME AJYH22-CME
View Count: 554
[2022-02-03 07:38:06] |
Sargon Petros - Posts: 57 |
Hi there, For some reason I can't seem to see anything when I use the DOM with AJYH22-CME. I can get data in the charts though. I'm subscribed to the relevant exchange feed too. Is anyone else experiencing this issue? |
[2022-02-03 15:11:17] |
John - SC Support - Posts: 38443 |
This is a sparsely traded instrument, so we do not understand what you would expect to see in the Trading DOM. For the most part, the price is going to stay static, so the Trading DOM will not be changing. If you do not have any prices displayed in the Trading DOM then right-click where the Price Ladder should be and select Auto-Scale the Chart DOM. This should fix the issue. If it is something else altogether, then please get us a screenshot of what you are seeing (or not seeing) and some additional information on the exact problem you are having. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-02-09 17:52:42] |
Hey there, What I meant is that there doesnt seem to be any market depth. Please see the attached. Would you suggest a more suitable instrument for this pair? I noticed ICE is no longer supported. Date Time Of Last Edit: 2022-02-09 17:53:56
[2022-02-09 19:06:24] |
We do not see anything either. But given the low volume, this is not surprising. We do not know a better option for trading this pair. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
