Date/Time: Thu, 06 Mar 2025 14:10:51 +0000
Denali - How to Access Full Market Depth
View Count: 1071
[2022-02-03 06:21:45] |
user_xyz - Posts: 449 |
It appears I'm not seeing full market depth on all CME products. CL as an example I can view approximately $1 or ~100 ticks yet the market depth is much more than that. Is there a setting I need to change? Data Trade Services > Max Time & Sales is 0 and Chart DOM > Chart Settings > Market Depth is 0. Thanks! Denali - "Full order book. All levels of market depth will be provided. If there are 1000 levels of depth, there will be 1000 levels of depth visible." |
[2022-02-03 06:35:10] |
Refer to: File Menu: Not Receiving the Full Number of Market Depth Levels Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-02-03 13:58:40] |
Thank you this setting -- Global Settings -> Sierra Chart Server Settings was at 100 (maybe default) changing it to 0 displays everything I need.
[2022-02-03 17:59:19] |
Also with that number of market depth levels, update to the latest prerelease for the best performance: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
