Date/Time: Fri, 18 Sep 2026 14:51:50 +0000
Any Ideas About How To Create Graphical Performance Dashboards?
View Count: 2244
[2022-02-02 22:18:17]
User274555 - Posts: 14
In the past I have used brokerage accounts like Stage5, Tradovate and EdgeClear that all have built in graphical performance monitor dashboards.
I realize that SC has all of this same performance data (and more) that can be easily viewed in the trade activity log.
Does anyone (SC developers or experienced users) have any experience with or ideas about how one could export the trade activity log data and perhaps upload into a third party dashboard tool to create the same type of visual charts, graphs etc?
I'm thinking it likely involves something along the lines of converting one of the exported trade activity logs into excel then uploading it into a third party dashboard tool.
I'm just fishing for ideas here as I'm sure someone smarter than me has probably figured this out already.
Thanks in advance to anyone that can contribute any ideas or perhaps point me to thread where this has covered ( I did search the forum but couldn't seem to locate anything on the topic.)
Date Time Of Last Edit: 2022-02-02 23:36:23
[2022-02-03 02:54:23]
ondafringe - Posts: 337
I think you can pretty much do all that using spreadsheet software. You really don't even need to export. For instance, on the Trade Activity log, you can Edit > Copy All, paste into a spreadsheet, delete what you don't want, then crunch the numbers and present the results in whatever format you want (assuming you know how to use a spreadsheet).
I use a spreadsheet to track my performance, but I input my trades manually. And I'm not into the graphical stuff, I just want to see the bottom-line numbers.
Date Time Of Last Edit: 2022-02-03 02:59:50
[2022-02-03 03:28:17]
theunknowntrader - Posts: 112
You can just export your trades into a spreadsheet and have tables, charts, graphs linked for the cost of $0.
[2022-02-03 09:59:41]
Ticks - Posts: 212
@User274555
I export trade activity and upload to Edgewonk to view performance metrics.
https://edgewonk.com/
Tradersync also works great.
https://tradersync.com/
[2022-02-03 14:02:10]
user_xyz - Posts: 520
+1 on the spreadsheet. You can create macros assigned to buttons to simplify certain tasks.
Date Time Of Last Edit: 2022-02-03 14:04:42
[2026-08-23 00:28:46]
Benhouse - Posts: 5
@User274555
I try also export trade activity and import on Tradoshi Trading Journal,
it work perfectly.
https://tradoshi.com
Before tradoshi I was using tradezella it is the reference, it is working too.
Date Time Of Last Edit: 2026-08-31 00:21:45
