Date/Time: Thu, 28 Nov 2024 13:44:30 +0000
# Candle stick border thickness
View Count: 567
[2022-02-02 17:41:23]
User478380 - Posts: 184
Can one make the border on a candle stick thicker and set it to different colours please ?
QS
[2023-04-25 13:11:40]
Does anyone have an update on my prior request about how to increase the thickness of the border on candle stick bars?
Thanks!
[2023-04-25 15:05:05]
John - SC Support - Posts: 36350
Global Settings >> Graphics Settings >> Candlestick Up Outline/Candlestick Down Outline
You can change both the color and thickness with these settings. Refer to the following:
Graphics Settings: Candlestick Up Outline
[2023-04-25 21:14:51]
Thanks. I did try what you said but it only changes the thickness of the border on the candle body itself. What it doesn't do is change the thickness of the wicks on the candles. How do I achieve that to make it easier to see the actual wicks please?
Regards!
[2023-04-25 21:29:49]
The account from which you are posting is Expired. If you have an active Sierra Chart account, then you need to post from that account. Otherwise, we will not answer any further questions from an expired account.
[2023-04-25 21:35:57]
cmet - Posts: 552
Wick thickness is controlled by the Bar High/Low settings in Chart Graphics.
[2023-04-25 21:45:23]
Pretty awesome
Nice one!!!!!
[2023-04-25 21:53:51]
Its expired because my trial is over and I only submitted the forms to Stage 5 today. I was under the impression I could use data from Ninja Trader but I was told this was not possible and I need the denali feed for package 10 of sierra. Please do not suspend my support tickets because I am becoming familiar with the system. Once funds clear tomorrow, I will be able to purchase system 10 and it will no longer be expired. I am basically having to learn a completely new charting and trading platform....
[2023-04-26 15:34:28]
Thank you for resolving this issue very quickly !
