Date/Time: Thu, 06 Mar 2025 13:22:30 +0000
measuring change in top 5 stocks in S&P
View Count: 538
[2022-02-02 16:18:35]
User313147 - Posts: 48
Is there a way in sierra to measure the top 5 stocks in S&P 500 in terms of there performance?
[2022-02-02 19:43:54]
John - SC Support - Posts: 38425
If you loaded all the stocks into the Quote Board, then you can sort based on whatever field you want. Refer to the following:
Getting Quotes: Quote Board
