Date/Time: Thu, 06 Mar 2025 12:45:40 +0000
Window who stays open
View Count: 457
[2022-02-02 15:31:17] |
User67370 - Posts: 2 |
Hello I removed ask/bid volume difference bars from my footprint but the gap window in between the footprint and delta numbers seems to stay open and i can not delete to fill the gap? Any help? Thanks https://www.sierrachart.com/Download.php?Folder=TicketingSystem&download=60740 |
[2022-02-02 18:49:36] |
John - SC Support - Posts: 38425 |
You need to adjust the Chart Region setting for the existing studies to use that particular Chart Region and not use ones after it. Refer to: Chart Studies: Settings and Inputs Tab >> Chart Region For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
