Date/Time: Thu, 06 Mar 2025 13:25:37 +0000
Cannot Connect
View Count: 430
[2022-02-02 15:18:52] |
User951690 - Posts: 2 |
I can't connect to my charts as of 1:55 pm on Feb. 1. Why are my charts not connecting?
[2022-02-02 16:26:28] |
This is a Transact server issue that Sierra Chart has no control over. Also please refer to this thread: *Important* Priority Message to Transact Users Let us know if you have any further questions. To access historical and streaming market data independent from your Trading service. Follow these instructions. Set "Global Settings >> Data/Trade Service Settings >> Current Selected Service" to "SC Data-All Services". Press "OK" And then translate the symbols in your Chartbooks and Sierra Chart using this "Edit' menu command: Edit Menu: Edit >> Translate Symbols To Current Service (Translate Symbols to Current Service) You can then use the data provided by Sierra Chart independent of your trading service. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
