Date/Time: Thu, 06 Mar 2025 12:55:40 +0000
# Trading from charts
View Count: 534
[2022-02-02 15:16:00] |
User478380 - Posts: 184 |
Hi Is it possible to right click on a chart with ones cursor and then select buy stop or sell limit wherever the cursor is please ? If so, do you have more info on this functionality? Thanks QS |
[2022-02-02 18:36:02] |
John - SC Support - Posts: 38425 |
Refer to the information for customizing the Chart Trade Menu: Global Settings Menu: Customize Chart Trade Menu (Global Settings menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
