Date/Time: Fri, 07 Mar 2025 00:51:39 +0000
problem with the new data feed.
View Count: 638
[2022-02-02 09:36:04]
User278398 - Posts: 291
hello,
i'm trying get market depth of NIO stock.
how can i get this data?
please check the attach pic*
regards
image2.png / V - Attached On 2022-02-02 09:31:55 UTC - Size: 134.05 KB - 149 views
image1.png / V - Attached On 2022-02-02 09:32:06 UTC - Size: 502.59 KB - 149 views
image3.png / V - Attached On 2022-02-02 09:34:54 UTC - Size: 220.89 KB - 148 views
[2022-02-02 14:08:08]
That is not the correct symbol.
The symbol format is explained here:
How to Use New NASDAQ Total View Data Feed | Post: 293966
[2022-02-08 13:03:35]
thank u. but it still not working for me for NIO stock (for IBM stock it is working!)
what i need to write to see level 2 for NIO ?
image1.png / V - Attached On 2022-02-08 13:01:55 UTC - Size: 502.59 KB - 137 views
[2022-02-18 01:13:47]
You need to update Sierra Chart to the current version. Instructions:
Date Time Of Last Edit: 2022-02-18 01:13:53
