Date/Time: Thu, 06 Mar 2025 12:53:28 +0000
Moved To Teton - web based trade panel is not working
View Count: 642
[2022-02-02 07:58:42] |
RIFT - Posts: 124 |
I'm at advantage futures, switched from TT to Teton, the web based trade panel doesn't work, I can't create a connect, see the screenshot. Another question, my SC account is registered with a Hungarian address, but my trading desk is now in Austria. Do I have to make any server settings because of Teton Routing or do you make new server settings because of the location in Austria? I trade on the NYMEX. |
[2022-02-02 18:09:40] |
Sierra_Chart Engineering - Posts: 18669 |
We will test.
[2022-02-02 19:08:49] |
Reload the web-based trading page within your web browser and see if you have any issue now. Some changes have been made related to connectivity.
[2022-02-02 19:53:35] |
RIFT - Posts: 124 |
Thanks, web based trading panel is working now! Server settings because of the trading location in Austria is ok?
[2022-02-02 21:13:27] |
It does not matter your location.
