Date/Time: Thu, 06 Mar 2025 14:11:52 +0000
Trading System Opening Multiple Orders When Limit Is Hit
View Count: 477
[2022-02-01 22:00:52] |
GG - Posts: 20 |
Hi, Been using Sierrachart for few years now, but new to the autotrade feature. While backtesting a system of crossing the middle band of VWAP I've run into an error. I want only one open trade running at a time, but once my limit or stop is hit, it opens multiple trades at a time in the direction of the original trade. (E.g. Price crosses above middle VWAP, buy position active, stop loss (limit) hit, 12 more buy positions open) Order Quantity: 1 Allow Multiple Entries in Same Direction: 0 Allow Entry With Working Order: 0 Maximum Position Allowed: 1 Buy Entry =CROSSFROMBELOW(ID0.SG4@3:ID0.SG4@4, ID5.SG1@3:ID5.SG1@4) Sell Entry =CROSSFROMABOVE(ID0.SG4@3:ID0.SG4@4, ID5.SG1@3:ID5.SG1@4) Using target and stop setting on Trade Window rather than L3 and N3, although I have tried to use those instead and the error still occured. Thanks, G. Hill |
[2022-02-03 18:17:58] |
So you end up with a Position Quantity of more than one? Double check the settings you mention.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-02-03 18:18:08
