Date/Time: Thu, 06 Mar 2025 09:35:32 +0000
Nadaq TV - feed custom formula - not working
View Count: 509
[2022-02-01 20:52:52]
ejtrader - Posts: 688
SC Team - Trying to use the custom symbol ( -1*{VXX-NQTV ) - is not working with Nasdaq total view. Unable to receive the data with this custom symbol. The underlying symbol VXX-NQTV is working though.
Could you please check and post the custom symbol settings for this? If it matters - using it with SC direct CME routing trading service.
Message in the log file - and the chart never gets populated.
-1*{VXX-NQTV} 5 Min #4 | Reloading chart. | 2022-02-01 14:51:52.610
-1*{VXX-NQTV} 5 Min #4 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart_Data\Data\-1%{VXX-NQTV}.scid | 2022-02-01 14:51:52.618
[2022-02-01 23:09:15]
John - SC Support - Posts: 38425
We just tried this and it worked fine for us. Did you duplicate the symbol settings and update them as required in order to create a Custom Calculated Symbol? Refer to the instructions here:
Custom Calculated Symbols
[2022-02-02 00:16:09]
SC Team - I did duplicate the symbol and updated the formula. This didn't work in the Teton instance first until I disconnected the datafeed and connected again.
In Delayed feed instance it worked fine without disconnect/reconnect.
It's all good now.
