Date/Time: Thu, 06 Mar 2025 09:55:35 +0000
Denal Feed 11
View Count: 460
[2022-02-01 18:07:53] |
sueuwe - Posts: 2 |
Hi there, I have purchased the Sierra Chart Denali Data Feed Service Pack 11. The data differs by about 15-20 ticks in all markets. Why is that? What do I have to do so that the data feed is not delayed? Best regards Uwe |
[2022-02-01 19:13:48] |
John - SC Support - Posts: 38425 |
You need to go through all of the Setup Instructions for the Denali Exchange Data Feed for the CME Group. You will find the instructions here: Denali Exchange Data Feed: *Setup Instructions: CME/CBOT/NYMEX/COMEX Exchanges* If you are wanting data for EUREX or CFE, then those instructions are on the same page. Just scroll to the top and select the appropriate link. If you are wanting data for U.S. Stocks, then refer to the instructions in this posting: How to Use New NASDAQ Total View Data Feed For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
