Date/Time: Thu, 06 Mar 2025 13:03:42 +0000
Bulk Add NASDAQ TotalView Symbols to Associated Watchlist for Scanning
View Count: 527
[2022-02-01 16:33:13] |
fykemang - Posts: 49 |
Thank you for adding the new NASDAQ TotalView data. I know that it is currently possible to add all NASDAQ listed stocks to an associated watchlist for scanning. However, the symbols added still rely on the delayed historical data feed. Is there currently any way to bulk add stocks from an index where the symbols are using the new NASDAQ TotalView data? Also, are there any kind of symbol limits for the NASDAQ TotalView data? How many real-time symbols do I have at once? |
[2022-02-01 17:32:39] |
John - SC Support - Posts: 38425 |
There is not currently a way to do this. We will have to look into it. Also, are there any kind of symbol limits for the NASDAQ TotalView data? How many real-time symbols do I have at once?
There are no symbol limits with the NASDAQ data feed. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-02-02 08:02:34] |
You can Import files into the associated watchlist for a chart, so you can prepare the symbols in a text file and import that.
