Date/Time: Thu, 06 Mar 2025 09:47:13 +0000
sc.PreviousClose
View Count: 516
[2022-02-01 15:49:15]
User493647 - Posts: 5
Hello, concerning the "sc.PreviousClose" variable, is it referenced by a subgraph of ID0 (historical chart daily), if not, can you predict it please? Thank you for your reply
[2022-02-01 16:56:27]
1+1=10 - Posts: 270
Hi User,
Did you read the docs?:
ACSIL Interface Members - Variables and Arrays: sc.PreviousClose
sc.PreviousClose
Type: Read-only float variable.
The sc.PreviousClose variable contains the current Settlement Price obtained from the Current Quote data.
I think you're confused about how subgraphs work -- it is used for you to write data out from your study -- it has nothing to do with getting data from the chart. Perhaps I can help. What are you hoping to accomplish? Get the close values of certain previous bars in a Daily chart?
