Date/Time: Thu, 06 Mar 2025 09:35:12 +0000
Cost Effective Account / Service Configuration
View Count: 513
[2022-02-01 15:47:16] |
mavivenzio - Posts: 1 |
Trying to migrate to SC for charting and trades for a close to full turn key set up. Used to commission only pricing.. Current Accounts: IB, TradeStation, Tradovate, MotiveWave all non pro accounts Needs: Realtime data, CME data only ($ES $MES...) with market depth. Little to no exchange fees... What would be the most cost effective configuration? Denali Data Feed or Teton? Total monthly all in cost? I would not be opposed to opening another account i.e Edge Clear etc. Let me know if there are other questions needed to be answered.. Thanks in advance! |
[2022-02-01 16:58:10] |
John - SC Support - Posts: 38425 |
Our recommendation is to use the Teton Order Routing service with our Denali Exchange Data Feed. Refer to the following regarding the Teton Order Routing: Sierra Chart Teton Futures Order Routing And refer to the following regarding the Denali Exchange Data Feed: Denali Exchange Data Feed Also refer to the following for the Package pricing, you would need to be on package 10, 11, or 12 to use the Denali Exchange Data Feed: Description of Service Packages and Pricing: Packages -- The information above has all the data for you to put together the cost. We do not know what your needs are in terms of Package or data. But you can determine it from the above. Also note that with the Teton Order Routing Service there is a list of supported brokers at Step #2 in the Setup Instructions. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
