Date/Time: Mon, 14 Sep 2026 13:52:06 +0000
cannot connect to service
View Count: 742
[2022-02-01 15:43:42]
User203762 - Posts: 12
i received the attached message
service connection error
connection error message from service CQGWebAPI| Logon unsuccessful. server message: Your logon is disabled, contact your FCM| Time: 2022-02-01 09:01:34
Could you please fix it asap
[2022-02-01 16:54:23]
John - SC Support - Posts: 47854
As the message states, your login to CQG has been disabled. You need to ask your broker about this.
[2022-02-01 20:00:28]
Refer to number 12 here:
CQG Trading Platform Service: Common Error Messages
To access historical and streaming market data independent from your Trading service. Follow these instructions.
Set "Global Settings >> Data/Trade Service Settings >> Current Selected Service" to "SC Data-All Services".
Press "OK"
And then translate the symbols in your Chartbooks and Sierra Chart using this "Edit' menu command:
Edit Menu: Edit >> Translate Symbols To Current Service (Translate Symbols to Current Service)
You can then use the data provided by Sierra Chart independent of your trading service.
Date Time Of Last Edit: 2022-02-01 20:01:54
