Date/Time: Fri, 25 Sep 2026 11:41:56 +0000
Graphique qui avance tout seul
View Count: 1011
| [2022-02-01 15:36:25] |
| Utilisateur188232 - Posts: 22 |
Bonjour, comment puis je faire pour que mon graphique foot print suive le prix tout seul toute la journée ? Merci de votre réponse. |
| [2022-02-01 16:42:49] |
| John - SC Support - Posts: 48003 |
From Google Translate: Hello, how can I make my foot print chart follow the price on its own all day?
We are not understanding the question. The Footprint chart will automatically follow the price, as long as your Scale setting is set to "Automatic". Refer to the following for information on Scale: Chart Scale and Scale Adjusting For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
