Date/Time: Thu, 06 Mar 2025 10:13:11 +0000
[User Discussion] - how do I get xbtusd-bmex data
View Count: 935
[2022-02-01 15:22:05]
User849502 - Posts: 355
I can't figure out how I add the above so I can chart bitcoin. What exchange or whatever do I add to get that data. thanks anyone.
[2022-02-01 16:37:32]
John - SC Support - Posts: 38425
Since you are connecting to the Teton Order Routing Service in your Sierra Chart, you would need to install a second Sierra Chart and then leave the Data/Trade Service Settings >> Current Selected Service set to SC Data - All Services. You will then be able to get the Crypto data from us. Refer to the following for installing another Sierra Chart:
Using Multiple Data and Trading Services at the Same Time: Step-By-Step Instructions to Install Multiple Copies of Sierra Chart
And refer to the following regarding the Crypto data available from Sierra Chart:
Cryptocurrency / Bitcoin Data and Trading Services
