Date/Time: Thu, 06 Mar 2025 09:38:38 +0000
Is a Subgraph Level Line extendable to the Display Region 2 Right Border?
View Count: 588
[2022-02-01 15:02:25] |
User14953 - Posts: 243 |
Study Setting >> Subgraph Tab >> Subgraph is Hi Level, Line, Solid I can't find a setting to configure a Subgraph Level Line to extend through the Fill Space to the Region 2 Right Border similar to the way the Pivot Points study output extends past the last price bar through the Fill Space to the Region 1 Right Border. Is there a way to do this? Thanks |
[2022-02-01 16:31:15] |
John - SC Support - Posts: 38425 |
Refer to the following Draw Style: Chart Studies: Line Extend To Edge (ACSIL: DRAWSTYLE_LINE_EXTEND_TO_EDGE) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
