Date/Time: Tue, 29 Sep 2026 12:16:32 +0000
Data Trade Services
View Count: 891
| [2022-02-01 15:00:47] |
| User787305 - Posts: 25 |
I have an account with Apex Futures/StoneX (Used to be Gain Capital). I have live data streaming through Apex with CQG. My issue: Lack of Historical intraday data and streaming data interrupted intraday. I have read your Help dialog on this issue. Your Support documentation discusses historical data streaming issues under the Continuous Futures Contracts. I need Historical data for S&P E-mini, micro-mini. Based on your documentation, it's apparent I should move to Support 10,11,or 12 and use the Denali Exchange Data Feed or Sierra Chart Hostorical Data Service for order routing. Will this approach work with my Apex/Gain/StoneX account to place orders through Sierra Charts? Your advice is appreciated Michael Date Time Of Last Edit: 2022-02-01 15:02:40
| [2022-02-01 15:18:21] |
Yes you definitely need to use the Denali Exchange Data Feed when using CQG. Full documentation and instructions: Denali Exchange Data Feed Will this approach work with my Apex/Gain/StoneX account to place orders through Sierra Charts?
Yes absolutely.Let us know if you need help with the data feed set up. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-02-01 15:18:45
| [2022-02-01 15:53:53] |
Thank you. I would appreciate your guidance with the set-up. I will read the instructions for the Denali Exchange Data Feed. I would guess my questions will center around setting up the Data Trade Services userid/password window. Obviously, I have my Apex userid and password: Server: prod.gainfutures.com; username: MAllen5057, Trade Account: ATG9174. Thanks again for your support. |
