Date/Time: Thu, 06 Mar 2025 10:07:38 +0000
The instructions to the NASDAQ data
View Count: 540
[2022-02-01 09:14:58] |
Пользователь488020 - Posts: 100 |
In the instructions How to Use New NASDAQ Total View Data Feed I want to get an explanation for points 2 and 3. Do I need to fill in both items if I am not a professional and I need real-time data? I will trade from a third-party application.
[2022-02-01 13:10:07] |
The answer is yes to both of those.
