Date/Time: Tue, 06 Oct 2026 13:40:21 +0000
Teton sim mode sub instance
View Count: 951
[2022-02-01 08:30:05]
RIFT - Posts: 124
I switched from TT to Teton routing. When I'm in Live mode, I can see the orders on all instances, but not in Sim mode. Should I make any settings so that it also works in sim mode?
[2022-02-01 13:22:42]
If you are referring to the orders on the Teton system, you do need to disable the sub instance Trade >> Trade Simulation Mode On.
Although probably does not matter if you just want to see orders within the Trade >> Trade Orders Window. We will check on this.
Date Time Of Last Edit: 2022-02-01 13:24:19
[2022-02-01 15:16:58]
Regarding what you are describing in post #1, we are definitely not seeing any issue. Refer to:
Chart Trading and the Chart DOM: Viewing Orders and Trade Position on the Chart / Trade DOM
[2022-02-01 15:45:22]
RIFT - Posts: 124
see the screenshot... Instance 1 on the Dom 88.30 I have a buy stop order, but it is not visible on instance 2. Sim 1 is set on both instances. "show orders and position" is enable and "only orders from chart" is disabled on both instances. As I mentioned before, Live mode works.
Date Time Of Last Edit: 2022-02-01 15:47:13
imageTeton.sub.instance.jpg / V - Attached On 2022-02-01 15:45:16 UTC - Size: 5.21 MB - 236 views
[2022-02-01 16:01:17]
RIFT - Posts: 124
see the screenshot in Live mode, the settings are the same as before
imageTeton.sub.instance.live.jpg / V - Attached On 2022-02-01 16:01:10 UTC - Size: 6.3 MB - 293 views
[2022-02-07 20:32:49]
These are overly complex screenshots to be providing us.
In the sub instance you must disable this setting:
Trade Menu: Trade Simulation Mode On (Trade menu)
We will make sure the documentation explains this but we are fairly sure it does.
