Date/Time: Thu, 06 Mar 2025 09:29:00 +0000
Sierra wont conect to server in evening
View Count: 525
[2022-02-01 01:52:06]
User619996 - Posts: 1
The es market reopens at 6pm New York time but I cant reconnect.
It's almost 8pm now. This has happened several times. It will connect eventually it seems.
I don't always connect in the evening so I don't know if it always won't connect.
[2022-02-01 02:24:06]
Please move off of Transact as soon as possible. We cannot help with this issue. It is a Transact server issue. Refer to:
*Important* Priority Message to Transact Users
We want to help you, so please read the information linked above. We can put you in contact with a broker.
[2022-02-01 02:45:02]
Stage 5 Trading Corp. - Posts: 31
As a former Infinity Broker I fully understand the trials and tribulations of changing brokerage firms. As far as I understand, the Transact connection is in the process of no longer being supported by Sierra Chart. Stage 5 takes great pride in helping Transact/Infinity traders transition as seamlessly as possible. I believe the best solution would be to switch to Sierra Teton Order Routing with Denali for real time and historical data. This is all maintained by Sierra directly, which I feel provides great benefits to traders as Sierra can focus on enhancements instead of maintenance of other third party order routing feeds. In addition, I feel it is the best overall quality and value for traders.
Please feel free to contact us and we will gladly assist you with any questions you may have and/or the process of transitioning your account and hopefully helping you improve your current issues.
If you have questions or would like to speak to an assigned personal broker for details, please call us at 312-896-9897 or 1-800-258-6675. You can email us at sierrachart@s5trading.com and can also contact us here: https://stage5trading.com/contact/
If you are ready to move to the Teton Order Routing solution right away, we invite you to file an application here: https://stage5trading.com/
Thank you,
Anthony Giacomin
Trading derivatives carries a high degree of risk, and may not be suitable for all investors. Past performance is not necessarily indicative of future results.
