Date/Time: Thu, 06 Mar 2025 09:32:22 +0000
ChartDOM - Add 3 more General Purpose Columns
View Count: 457
[2022-01-31 22:44:52] |
ejtrader - Posts: 688 |
SC Team - My prior request on this was marked as User discussion. Would it be possible to add 3 more general purpose columns to the existing 2 General Purpose columns you currently have? As you already have the required framework on this - assuming this might be feasible to add 3 more columns. Atleast can you mark it as feature request? Thanks |
[2022-01-31 23:13:05] |
John - SC Support - Posts: 38425 |
We have set this as a Feature Request. But, when a thread that makes a request is marked as a "User Discussion", it is the same as if it was marked "Feature Request". The option for "Feature Request" is a relatively recent addition, so previously the "User Discussion" was used to mark these. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
