Date/Time: Thu, 06 Mar 2025 09:37:04 +0000
Order Allocation to Trade Accounts
View Count: 558
[2022-01-31 21:51:05]
User630795 - Posts: 92
I day trade /NQ exclusively using Sierra Chart (version 2339 64-bit), AMP Futures account, and CQG data feed (and order routing?). All my orders are entered in the DOM (SC). I want my all my orders to be duplicated (& executed) on my second account (w/ AMP Futures). If I use "MENU > SETTINGS > ORDER ALLOCATION TO TRADE ACCOUNTS" and choose both accounts, would all my orders (buy, sell, cancel all, flatten, ...etc) and quantity be duplicated and executed in both accounts exactly same?
Thank you for your response in advande.
Steve
[2022-01-31 22:41:41]
John - SC Support - Posts: 38425
Yes. Refer to the following:
Just be sure you spend some time working with the functionality, as it is fairly limited in what it can do at this time.
[2022-02-01 14:07:40]
i wish you guys give more detailed answer/response.
I already read the link you provided.
I asked because i wanted to make sure because you obviously don't want to use/trade with it w/o understanding the "limits" clearly.
so, what are the "limits" you mentioned?
Pls be as detailed as possible.
thank you.
