Date/Time: Thu, 06 Mar 2025 09:29:48 +0000
Trade DOM
View Count: 500
[2022-01-31 17:41:48] |
User976943 - Posts: 39 |
Hi, How can I open a Trade DOM for a detached chart? Thanks |
[2022-01-31 18:07:45] |
John - SC Support - Posts: 38425 |
Keep in mind, a Trading DOM is not directly associated with a chart. The only connection is the symbol. Therefore, you just need to open a Trading DOM from the Find Symbol window and select the specific symbol you want, or duplicate a Trading DOM and change the symbol. Refer to the following: Chart Trading and the Chart DOM: Trade DOM For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
