Date/Time: Thu, 06 Mar 2025 09:31:00 +0000
Edit values in Region Data Lines
View Count: 846
[2022-01-31 16:45:22] |
User554580 - Posts: 11 |
Hello, How do I edit the values in the Region Data Lines? For example, I would like the DChg to be displayed as a percentage rather than a dollar amount. I found the Region Data Lines section in Chart Settings, Advanced Settings 2, but cannot see how to edit the values. Thanks! |
[2022-01-31 17:42:48] |
John - SC Support - Posts: 38425 |
Refer to the following: Global Settings Menu: Customize Chart Header - Standard (Global Settings menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
