Date/Time: Thu, 06 Mar 2025 12:46:31 +0000
[User Discussion] - Can I customize the order entry display?
View Count: 573
[2022-01-31 16:16:54]
MecGrp - Posts: 12
I think there is too much redundant data in the data entry so can I customize what is displayed. All I want to see is the # of contracts and if am short or long.
imageOrderEntriesData.png / V - Attached On 2022-01-31 16:15:47 UTC - Size: 82.75 KB - 153 views
[2022-01-31 20:16:40]
Sawtooth - Posts: 4179
Go to Global Settings >> Chart Trade Settings >> Order Fills tab, and select what you want displayed.
[2022-02-04 16:49:54]
MecGrp - Posts: 12
Thank You! That helped
imageOrderEntriesData-Fixed.png / V - Attached On 2022-02-04 16:49:04 UTC - Size: 76.13 KB - 135 views
