Date/Time: Thu, 06 Mar 2025 09:57:00 +0000
activation
View Count: 400
[2022-01-31 15:22:34] |
User804361 - Posts: 1 |
how can I activate my footprint chart and which service is required to use footprint chart ?
[2022-01-31 17:25:28] |
John - SC Support - Posts: 38425 |
You need to be on the Advanced Package. We also recommend using the Denali Exchange Data Feed for your data. Refer to the following for information on the Packages: Description of Service Packages and Pricing: Packages Refer to the following for selecting a package: Sierra Chart Purchase and License Information: Instructions For the Denali Exchange Data Feed, refer to the instructions here for the CME Group data: Denali Exchange Data Feed: *Setup Instructions: CME/CBOT/NYMEX/COMEX Exchanges* Let us know if you need help with any of this. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-01-31 17:32:43
