Date/Time: Tue, 06 Oct 2026 00:31:15 +0000
Real time data
View Count: 785
[2022-01-31 15:17:49]
User409689 - Posts: 3
Hey! I want to have access to real time data with tape (time and sales and depth) for stocks. Just subscribed to the Denali real time data with level 12, was wondering if I did the right thing? Thanks!
[2022-01-31 21:23:56]
John - SC Support - Posts: 48114
You have the right idea, but you are one day early. Our new NASDAQ data feed for U.S. Stocks will be available tomorrow (February 1, 2022).
Also, you state that you want access to the Time and Sales and the Depth. Package 12 is specifically for the Market by Order data, which will be available with the NASDAQ exchange, so if you are wanting that, then you are fine. But if you just want the Market Depth, then you can be on Package 10 or 11. Refer to the following regarding Market by Order data:
Market By Order Data
Also refer to the differences in the packages here:
Description of Service Packages and Pricing: Packages
[2022-02-02 18:12:01]
Will I get access to full depth so far it seems like I only have the NBBO,Thank you!
[2022-02-02 20:04:53]
You should have up to 1400 levels of Depth. If you are not getting these, then make sure you have the correct symbols - the symbols for the new NASDAQ TotalView need to have a -NQTV at the end. For example, Apple would be AAPL-NQTV. Without this extension you would be getting historical data from our other data feed.
