Date/Time: Thu, 06 Mar 2025 09:55:26 +0000
Chart and DOM font size
View Count: 709
[2022-01-31 15:16:53]
User850090 - Posts: 26
Hello. How can I fix font problem with my Chart DOM. When I open chart and DOM separately everything is fine. But when I attach Trade DOM to my chart all fonts in DOM are too small a overlapped. When I make them bigger my numbers bars are too big. See pictures. Thanks
https://www.sierrachart.com/Download.php?Folder=TicketingSystem&download=60659
https://www.sierrachart.com/Download.php?Folder=TicketingSystem&download=60665
[2022-01-31 18:57:52]
John - SC Support - Posts: 38425
Keep in mind that what you are seeing is due to the density of the data. The best "solution" is to combine the Bid/Ask data in the DOM so you can see the data there better. Otherwise, you just have to make the tradeoff of what you see in the DOM versus what you see in the Numbers Bars.
Refer to the following for how to combine increments in the DOM:
Chart Settings: Market Depth Combine Increment in Ticks (Chart >> Chart Settings >> Market Depth menu)
