Date/Time: Thu, 06 Mar 2025 09:35:51 +0000
Add data to window
View Count: 485
[2022-01-31 15:13:53] |
User552931 - Posts: 25 |
Hello, I want to add to the attached file window a sum of the total contracts in each column, in the red circle. How can I add it? Regards https://www.sierrachart.com/Download.php?Folder=TicketingSystem&download=60670 |
[2022-01-31 18:52:07] |
John - SC Support - Posts: 38425 |
First, you need to have the data you want in a study of some sort. So if you are looking for the Total Bid and Total Ask for a bar, then use the Numbers Bars Calculated Values and the subgraphs Ask Volume Total and Bid Volume Total. Then use the Study Subgraph Above/Below Bar As Text study to get that information displayed Above/Below the bar. Refer to the information here: Study Subgraph Above/Below Bar as Text For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
