Date/Time: Thu, 06 Mar 2025 09:57:11 +0000
How do I change order quantity buttons on DOM
View Count: 1491
[2022-01-31 14:51:06] |
User708382 - Posts: 3 |
How can I change the numbers on the order quantity buttons on the DOM? Mine are 1,2,4,5,8,0 I want them to be 1,2,3,4,5,6. I looked but cannot find the answer. Thanks |
[2022-01-31 15:46:14] |
Tonkadad - Posts: 235 |
Go to "Set" on Trade Window and change "Quantity Buttons at the bottom. Click the main button and then the "M" button next to "Cancel All" and "Save Configuration"
[2022-01-31 17:31:37] |
John - SC Support - Posts: 38425 |
The following is where you will find the documentation for changing the quantity buttons: Basic Trading and the Trade Window: Main/C >> Order Quantity Buttons For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
