Date/Time: Thu, 06 Mar 2025 09:30:51 +0000
Market Depth Historical Graph Feature Request
View Count: 453
[2022-01-31 14:07:52]
User852559 - Posts: 40
I'd like to request that you add a feature to the MDHG. Currently you can control whether you show quantity numbers in bars, after last bar or a combination of the two. I'd like to request that you add the ability to set this separately for the secondary numbers color for quantities greater than or equal to threshold.
For example, I'd like the ability to set the initial setting to show only after the last bar, but for any quantity greater than the threshold I'd like to show the quantity both in bar and after last bar.
Please let me know if this is something you could add. If you need any clarification let me know.
Thanks!
[2022-01-31 18:41:34]
John - SC Support - Posts: 38425
Just to make sure we understand - you want to be able to display ALL the quantities after the last bar, but only display quantities greater than a specific threshold within the bar data.
[2022-01-31 19:00:00]
Hello John,
Yes that is correct. As it currently stands having the quantities displayed in bar for all quantities puts a heavy load on processing. So being able to limit quantities within bar over a certain threshold would be a very useful feature.
So I am basically requesting that you add a second input that functions the same as the "Show Quantity Numbers" filter, but that applies only to the Secondary Numbers quantity threshold, so that these two inputs can be set independently.
[2022-01-31 19:22:17]
Ok. We have set this as a Feature Request.
Keep in mind, we do not know when we will be able to get to this. Setting it as a Feature Request just means that we recognize what you want and that it would be a change we would need to make. But there is a lot of items to implement and we can not do all of them.
