Date/Time: Fri, 07 Mar 2025 01:23:42 +0000
CQG + Denali data feed vs SC Data all services
View Count: 1195
[2022-01-31 04:16:12]
User729582 - Posts: 1
Hi, I'm using CQG live account trading + denali data feed. But when I flip between this and SC data all services, the tick charts differ by a little. My CQG trading account through Sierra Chart is setup to use Denali data, and therefore should be exactly the same as SC Data all services as far as I'm aware. I see the [M] next to the futures contract symbol.
[2022-01-31 18:28:36]
John - SC Support - Posts: 38467
Refer to:
Differences With Data and Chart Bars Between Services / Connections / Chart Types
[2022-02-19 04:46:31]
User216546 - Posts: 3
Hello, i switched over from CQG datafeed to Denali datafeed but when i enter an order on live it automatically submits order on sim why is that. It will not allow me to submit any live orders now that i switched over to Denali....
[2022-02-19 18:33:08]
The correct link for the question in post #1 is this one:
Regarding this, follow the instructions here:
Real-Time Exchange Data Feeds Available From Sierra Chart: Integration with Trading Services
You do need to set Sierra Chart to use CQG if that is the system that your broker set your account on.
Date Time Of Last Edit: 2022-02-19 18:34:42
