Date/Time: Thu, 06 Mar 2025 10:10:45 +0000
Long Time Sierra User -- Cannot Values Window
View Count: 464
[2022-01-30 22:34:04] |
User725605 - Posts: 60 |
I am a long time Sierra User. I have installed A New Copy of Sierra on many new machines in the past. This time around, all went well, except I cannot seem to get the interactive OHLC-Vol-Bid-Ask Data Window to show, that sits on top of all my charts. Normally I would go to the 'Chart - Reset Child Windows' - option, to bring this important window up. Please advise. |
[2022-01-30 22:54:59] |
Refer to: Chart Drawing Tools: Cannot See Values Windows? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-01-31 18:22:13] |
John - SC Support - Posts: 38425 |
Also, keep in mind that the window you are wanting is the Compact Tool Values Window. Make sure you have it selected under the Window menu. Refer to the following: Chart Drawing Tools: Compact Tool Values Window For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
