Date/Time: Thu, 06 Mar 2025 16:21:38 +0000
[Programming Help] - building dll from cpp; compile error
View Count: 664
[2022-01-30 18:09:29]
User283743 - Posts: 38
This is the error message:
-- Starting remote build of Custom Studies Source files: CustomStockIndexCreator.cpp. 64-bit -- 13:06:50
Allow time for the server to compile the files and build the DLL.
The remote build did not succeed. Result:
CustomStockIndexCreator.cpp: In function 'void scsf_CustomStockIndexCreator(SCStudyInterfaceRef)':
CustomStockIndexCreator.cpp:453:52: error: invalid conversion from 'int' to 'HistoricalChartBarPeriodEnum' [-fpermissive]
453 | OpenChartParameters.HistoricalChartBarPeriod = pBarPeriod;
| int
-- End of Build -- 13:06:54
[2022-01-31 18:11:08]
John - SC Support - Posts: 38440
The variable HistoricalChartBarPeriod is of type "HistoricalChartBarPeriodEnum", but your variable pBarPeriod is an "int". So your assignment of OpenChartParameters.HistoricalChartBarPeriod = pBarPeriod; does not work.
[2022-02-08 12:42:37]
Thanks for your reply.
When I roll back Sierra to the previous version,
the .dll is built without error message.
Would that change your diagnosis of the cause of the error message?
[2022-02-08 19:11:47]
1+1=10 - Posts: 270
@User283743,
Perhaps SC changed the API between those versions but sc.SetBarPeriodParameters() no longer has an "HistoricalChartBarPeriod" field:
ACSIL Interface Members - Functions: sc.SetBarPeriodParameters()
It only has "HistoricalChartBarPeriodType" and "HistoricalChartDaysPerBar"
