Date/Time: Tue, 08 Sep 2026 19:55:15 +0000
Question re Color Bars
View Count: 806
| [2022-01-30 18:06:34] |
| User39772 - Posts: 311 |
Hello, I understood that to change the candle color in a chart, depending on an study, the following steps are necessary: //Studygraph config Subgraph_Indicator.Name = "Indicator"; Subgraph_Indicator.DrawStyle = DRAWSTYLE_COLOR_BAR; Subgraph_Indicator.LineWidth = 5; Subgraph_Indicator.SecondaryColorUsed = true; Subgraph_Indicator.AutoColoring = true; Subgraph_Indicator.PrimaryColor = RGB(124, 252, 0); Subgraph_Indicator.SecondaryColor = RGB(242, 20, 20); Subgraph_Indicator.DrawZeros = false; if (condition) //Change candle color, if condition is true Subgraph_Indicator[sc.Index] = Subgraph_Indicator.PrimaryColor; else //Do not change candle color, if condition is not true //Because Subbgraph_Indicator.DrawZeros = false, color remains unchanged Subgraph_Indicator[sc.Index] = 0; The problem I see, is some unexpected behavior. On one hand the color changes as expected, but on the other hand I set the values of the indicator array to 0 at the current index, so that other code that makes use of this values, does not work properly. Can you tell me, if my understanding is wrong ? Date Time Of Last Edit: 2022-01-31 09:05:55
| [2022-01-31 03:41:32] |
| 1+1=10 - Posts: 270 |
“Subgraph_Indicator[sc.Index]” is for setting the value the subgraph. To set the color you have to use Subgraph_Indicator.DataColor[sc.Index] See further instructions here: ACSIL Programming Concepts: Custom Subgraph Coloring |
