Date/Time: Thu, 06 Mar 2025 09:34:53 +0000
periodic (ie not real-time), automatic data download for real-time symbols
View Count: 401
[2022-01-30 17:26:00] |
User12089 - Posts: 365 |
is there any way to setup SC to do - periodic (ie not real-time), automatic data download for real-time symbols for example the SC Data Feed has a feature to setup e.g. 5 min intervals for periodic download of data for non-realtime symbols. How about the same but for real-time symbol subscription/ Bascially i am a real-time SC datafeed symbols subscriber, BUT have a few really heavy compute charts which i only need to refresh them only ocassionaly e.g. every 10 min - if they are left on real-time refresh, they become close to ttoally unresponsive to UI commands |
[2022-01-30 17:55:09] |
No this is not supported.
[2022-01-31 03:47:57] |
1+1=10 - Posts: 270 |
If the compute is the issue, could you set the chart update interval, which determines how frequently the studies calculate, to a very high number?
