Date/Time: Thu, 06 Mar 2025 13:14:57 +0000
[Programming Help] - ACS Drawing Recalculation Performance
View Count: 709
[2022-01-29 17:19:06]
User907968 - Posts: 836
Version 2350 / Revsion 40878M
I am noticing significantly increased study recalculation times when more than one chart study is using ACS drawings such as 'DRAWING_LINE', 'DRAWING_RECTANGLEHIGHLIGHT', or 'DRAWING_RECTANGLE_EXT_HIGHLIGHT'.
None of these drawings are being added as user drawn, so based on the information here - Using Drawing Tools From an Advanced Custom Study: sc.DeleteACSChartDrawing() - I would assume that the drawings are all being deleted when the study is recalculated.
Here are some examples from testing today, calculation times are all microseconds.
Calculation/Recalculation times with study A is drawing to chart:
Chart: ESH22-CME[M] 2.50 Range #6 | Study: Drawing Test A | Study ID: 8 is Visible | Drawings Added by Study: 4485 | Total Drawings for All Studies: 4485 | Last Calculation Time: 34213 | 2022-01-29 09:58:58.020
Chart: ESH22-CME[M] 2.50 Range #6 | Study: Drawing Test 1 | Study ID: 4 is Hidden | Drawings Added by Study: 0 | Total Drawings for All Studies: 4485 | Last Calculation Time: 5772 | 2022-01-29 09:58:58.031
Chart: ESH22-CME[M] 2.50 Range #6 | Study: Drawing Test A | Study ID: 8 is Visible | Drawings Added by Study: 4485 | Total Drawings for All Studies: 4485 | Last Calculation Time: 33762 | 2022-01-29 09:58:58.739
Chart: ESH22-CME[M] 2.50 Range #6 | Study: Drawing Test 1 | Study ID: 4 is Hidden | Drawings Added by Study: 0 | Total Drawings for All Studies: 4485 | Last Calculation Time: 5705 | 2022-01-29 09:58:58.749
Chart: ESH22-CME[M] 2.50 Range #6 | Study: Drawing Test A | Study ID: 8 is Visible | Drawings Added by Study: 4485 | Total Drawings for All Studies: 4485 | Last Calculation Time: 34029 | 2022-01-29 09:58:59.789
Chart: ESH22-CME[M] 2.50 Range #6 | Study: Drawing Test 1 | Study ID: 4 is Hidden | Drawings Added by Study: 0 | Total Drawings for All Studies: 4485 | Last Calculation Time: 5774 | 2022-01-29 09:58:59.799
Initial Calculation times with both studies A and 1 drawing to chart:
Chart: ESH22-CME[M] 2.50 Range #6 | Study: Drawing Test A | Study ID: 8 is Visible | Drawings Added by Study: 4485 | Total Drawings for All Studies: 5563 | Last Calculation Time: 34298 | 2022-01-29 09:59:20.770
Chart: ESH22-CME[M] 2.50 Range #6 | Study: Drawing Test 1 | Study ID: 4 is Visible | Drawings Added by Study: 1078 | Total Drawings for All Studies: 5563 | Last Calculation Time: 6422 | 2022-01-29 09:59:21.555
Recalculation times with both studies drawing to chart:
Chart: ESH22-CME[M] 2.50 Range #6 | Study: Drawing Test A | Study ID: 8 is Visible | Drawings Added by Study: 4485 | Total Drawings for All Studies: 5563 | Last Calculation Time: 812016 | 2022-01-29 09:59:23.054
Chart: ESH22-CME[M] 2.50 Range #6 | Study: Drawing Test 1 | Study ID: 4 is Visible | Drawings Added by Study: 1078 | Total Drawings for All Studies: 5563 | Last Calculation Time: 781054 | 2022-01-29 09:59:23.830
Chart: ESH22-CME[M] 2.50 Range #6 | Study: Drawing Test A | Study ID: 8 is Visible | Drawings Added by Study: 4485 | Total Drawings for All Studies: 5563 | Last Calculation Time: 810877 | 2022-01-29 09:59:25.085
Chart: ESH22-CME[M] 2.50 Range #6 | Study: Drawing Test 1 | Study ID: 4 is Visible | Drawings Added by Study: 1078 | Total Drawings for All Studies: 5563 | Last Calculation Time: 772131 | 2022-01-29 09:59:25.862
Chart: ESH22-CME[M] 2.50 Range #6 | Study: Drawing Test A | Study ID: 8 is Visible | Drawings Added by Study: 4485 | Total Drawings for All Studies: 5563 | Last Calculation Time: 804666 | 2022-01-29 09:59:27.744
Chart: ESH22-CME[M] 2.50 Range #6 | Study: Drawing Test 1 | Study ID: 4 is Visible | Drawings Added by Study: 1078 | Total Drawings for All Studies: 5563 | Last Calculation Time: 772022 | 2022-01-29 09:59:28.530
I can reduce the days to load in the chart, so that there are fewer drawings to begin with, however the underlying behaviour is no different, the recalculation times increase disproportionately with each study added.
Whether this is a recent phenomenon, I can't say.
Date Time Of Last Edit: 2022-01-29 19:01:19
[2022-01-30 05:50:43]
Sierra_Chart Engineering - Posts: 18669
This does not mean anything to us. We have absolutely no idea what those studies are doing. And chart drawings are implemented as efficiently as possible.
Why? We have no idea. Only you can answer this. This is for you to determine. Those are the calculation times of your studies. Not Sierra Chart studies.
And whether the studies are visible or hidden, does not mean anything to us because that has no effect on calculation time. Anyone can verify that with Sierra Chart studies. You need to answer your own questions. We have no idea.
Date Time Of Last Edit: 2022-01-30 06:03:43
[2022-01-30 12:02:49]
Yes, ok understood.
Yes they are very efficient and the performance is excellent, normally.
Believe me, I tried to do this before contacting you. I've profiled and optimized my code where possible, but the end result is not changed.
The significance of visible vs. hidden in this case is that if the study is hidden, then ACS Drawings are not added during recalculation - this is why I showed the count of drawings in the log.
[2022-01-30 12:10:04]
I made a simple study that does nothing but add an ACS drawing at every nth bar (code attached).
This is the result.
All Studies Hidden i.e. no ACS Drawings:
Chart: ESH22-CME[M] 2.00 Range #1 | Study: ACS Chart Drawing Test | Study ID: 1 is Hidden | Drawings Added by Study: 0 | Total Drawings for All Studies: 0 | Last Calculation Time: 192 | 2022-01-30 05:58:42.624
Chart: ESH22-CME[M] 2.00 Range #1 | Study: ACS Chart Drawing Test | Study ID: 2 is Hidden | Drawings Added by Study: 0 | Total Drawings for All Studies: 0 | Last Calculation Time: 177 | 2022-01-30 05:58:42.624
Chart: ESH22-CME[M] 2.00 Range #1 | Study: ACS Chart Drawing Test | Study ID: 3 is Hidden | Drawings Added by Study: 0 | Total Drawings for All Studies: 0 | Last Calculation Time: 182 | 2022-01-30 05:58:42.624
Set Study ID 1 to visible, and press apply 3 times to make sure relevant values are shown in log:
Chart: ESH22-CME[M] 2.00 Range #1 | Study: ACS Chart Drawing Test | Study ID: 1 is Visible | Drawings Added by Study: 1000 | Total Drawings for All Studies: 1000 | Last Calculation Time: 193 | 2022-01-30 05:58:46.616
Chart: ESH22-CME[M] 2.00 Range #1 | Study: ACS Chart Drawing Test | Study ID: 2 is Hidden | Drawings Added by Study: 0 | Total Drawings for All Studies: 1000 | Last Calculation Time: 183 | 2022-01-30 05:58:46.617
Chart: ESH22-CME[M] 2.00 Range #1 | Study: ACS Chart Drawing Test | Study ID: 3 is Hidden | Drawings Added by Study: 0 | Total Drawings for All Studies: 1000 | Last Calculation Time: 176 | 2022-01-30 05:58:46.617
Chart: ESH22-CME[M] 2.00 Range #1 | Study: ACS Chart Drawing Test | Study ID: 1 is Visible | Drawings Added by Study: 1000 | Total Drawings for All Studies: 1000 | Last Calculation Time: 830 | 2022-01-30 05:58:48.533
Chart: ESH22-CME[M] 2.00 Range #1 | Study: ACS Chart Drawing Test | Study ID: 2 is Hidden | Drawings Added by Study: 0 | Total Drawings for All Studies: 1000 | Last Calculation Time: 179 | 2022-01-30 05:58:48.534
Chart: ESH22-CME[M] 2.00 Range #1 | Study: ACS Chart Drawing Test | Study ID: 3 is Hidden | Drawings Added by Study: 0 | Total Drawings for All Studies: 1000 | Last Calculation Time: 177 | 2022-01-30 05:58:48.534
Chart: ESH22-CME[M] 2.00 Range #1 | Study: ACS Chart Drawing Test | Study ID: 1 is Visible | Drawings Added by Study: 1000 | Total Drawings for All Studies: 1000 | Last Calculation Time: 843 | 2022-01-30 05:58:49.277
Chart: ESH22-CME[M] 2.00 Range #1 | Study: ACS Chart Drawing Test | Study ID: 2 is Hidden | Drawings Added by Study: 0 | Total Drawings for All Studies: 1000 | Last Calculation Time: 179 | 2022-01-30 05:58:49.278
Chart: ESH22-CME[M] 2.00 Range #1 | Study: ACS Chart Drawing Test | Study ID: 3 is Hidden | Drawings Added by Study: 0 | Total Drawings for All Studies: 1000 | Last Calculation Time: 177 | 2022-01-30 05:58:49.278
Set Study ID 2 to visible, and press apply 3 times to make sure relevant values are shown in log:
Chart: ESH22-CME[M] 2.00 Range #1 | Study: ACS Chart Drawing Test | Study ID: 1 is Visible | Drawings Added by Study: 1000 | Total Drawings for All Studies: 1000 | Last Calculation Time: 837 | 2022-01-30 05:58:55.730
Chart: ESH22-CME[M] 2.00 Range #1 | Study: ACS Chart Drawing Test | Study ID: 2 is Visible | Drawings Added by Study: 1000 | Total Drawings for All Studies: 2000 | Last Calculation Time: 179 | 2022-01-30 05:58:55.732
Chart: ESH22-CME[M] 2.00 Range #1 | Study: ACS Chart Drawing Test | Study ID: 3 is Hidden | Drawings Added by Study: 0 | Total Drawings for All Studies: 2000 | Last Calculation Time: 178 | 2022-01-30 05:58:55.732
Chart: ESH22-CME[M] 2.00 Range #1 | Study: ACS Chart Drawing Test | Study ID: 1 is Visible | Drawings Added by Study: 1000 | Total Drawings for All Studies: 2000 | Last Calculation Time: 838 | 2022-01-30 05:58:56.768
Chart: ESH22-CME[M] 2.00 Range #1 | Study: ACS Chart Drawing Test | Study ID: 2 is Visible | Drawings Added by Study: 1000 | Total Drawings for All Studies: 2000 | Last Calculation Time: 1320 | 2022-01-30 05:58:56.928
Chart: ESH22-CME[M] 2.00 Range #1 | Study: ACS Chart Drawing Test | Study ID: 3 is Hidden | Drawings Added by Study: 0 | Total Drawings for All Studies: 2000 | Last Calculation Time: 181 | 2022-01-30 05:58:56.928
Chart: ESH22-CME[M] 2.00 Range #1 | Study: ACS Chart Drawing Test | Study ID: 1 is Visible | Drawings Added by Study: 1000 | Total Drawings for All Studies: 2000 | Last Calculation Time: 160071 | 2022-01-30 05:58:57.627
Chart: ESH22-CME[M] 2.00 Range #1 | Study: ACS Chart Drawing Test | Study ID: 2 is Visible | Drawings Added by Study: 1000 | Total Drawings for All Studies: 2000 | Last Calculation Time: 160403 | 2022-01-30 05:58:57.786
Chart: ESH22-CME[M] 2.00 Range #1 | Study: ACS Chart Drawing Test | Study ID: 3 is Hidden | Drawings Added by Study: 0 | Total Drawings for All Studies: 2000 | Last Calculation Time: 193 | 2022-01-30 05:58:57.786
Chart: ESH22-CME[M] 2.00 Range #1 | Study: ACS Chart Drawing Test | Study ID: 1 is Visible | Drawings Added by Study: 1000 | Total Drawings for All Studies: 2000 | Last Calculation Time: 164135 | 2022-01-30 05:59:01.230
Chart: ESH22-CME[M] 2.00 Range #1 | Study: ACS Chart Drawing Test | Study ID: 2 is Visible | Drawings Added by Study: 1000 | Total Drawings for All Studies: 2000 | Last Calculation Time: 159101 | 2022-01-30 05:59:01.390
Chart: ESH22-CME[M] 2.00 Range #1 | Study: ACS Chart Drawing Test | Study ID: 3 is Visible | Drawings Added by Study: 1000 | Total Drawings for All Studies: 3000 | Last Calculation Time: 185 | 2022-01-30 05:59:01.392
Set Study ID 3 to visible, and press apply 3 times to make sure relevant values are shown in log:
Chart: ESH22-CME[M] 2.00 Range #1 | Study: ACS Chart Drawing Test | Study ID: 1 is Visible | Drawings Added by Study: 1000 | Total Drawings for All Studies: 3000 | Last Calculation Time: 160144 | 2022-01-30 05:59:02.470
Chart: ESH22-CME[M] 2.00 Range #1 | Study: ACS Chart Drawing Test | Study ID: 2 is Visible | Drawings Added by Study: 1000 | Total Drawings for All Studies: 3000 | Last Calculation Time: 160353 | 2022-01-30 05:59:02.788
Chart: ESH22-CME[M] 2.00 Range #1 | Study: ACS Chart Drawing Test | Study ID: 3 is Visible | Drawings Added by Study: 1000 | Total Drawings for All Studies: 3000 | Last Calculation Time: 1850 | 2022-01-30 05:59:03.105
Chart: ESH22-CME[M] 2.00 Range #1 | Study: ACS Chart Drawing Test | Study ID: 1 is Visible | Drawings Added by Study: 1000 | Total Drawings for All Studies: 3000 | Last Calculation Time: 319732 | 2022-01-30 05:59:03.976
Chart: ESH22-CME[M] 2.00 Range #1 | Study: ACS Chart Drawing Test | Study ID: 2 is Visible | Drawings Added by Study: 1000 | Total Drawings for All Studies: 3000 | Last Calculation Time: 318121 | 2022-01-30 05:59:04.297
Chart: ESH22-CME[M] 2.00 Range #1 | Study: ACS Chart Drawing Test | Study ID: 3 is Visible | Drawings Added by Study: 1000 | Total Drawings for All Studies: 3000 | Last Calculation Time: 317448 | 2022-01-30 05:59:04.616
Chart: ESH22-CME[M] 2.00 Range #1 | Study: ACS Chart Drawing Test | Study ID: 1 is Visible | Drawings Added by Study: 1000 | Total Drawings for All Studies: 3000 | Last Calculation Time: 319697 | 2022-01-30 05:59:07.274
Chart: ESH22-CME[M] 2.00 Range #1 | Study: ACS Chart Drawing Test | Study ID: 2 is Visible | Drawings Added by Study: 1000 | Total Drawings for All Studies: 3000 | Last Calculation Time: 320400 | 2022-01-30 05:59:07.592
Chart: ESH22-CME[M] 2.00 Range #1 | Study: ACS Chart Drawing Test | Study ID: 3 is Visible | Drawings Added by Study: 1000 | Total Drawings for All Studies: 3000 | Last Calculation Time: 319604 | 2022-01-30 05:59:07.912
Calcuation/Recalculation is very good, with only drawings from 1 study - but there is a big degradation as more studies with ACS Drawings are added.
Based on the simplicity of the attached code, I don't believe that this is a problem that I can solve, unless I am missing something?
attachmentChartDrawingTest.cpp - Attached On 2022-01-30 12:03:21 UTC - Size: 4.17 KB - 263 views
[2022-01-31 16:48:39]
Please review the attached video and let me know whether this is expected behavior or not.
The study used in the video is exactly that used (and included) in the previous post.
Date Time Of Last Edit: 2022-01-31 16:48:53
attachmentdrawing recalculation.mp4 - Attached On 2022-01-31 16:40:31 UTC - Size: 367.21 KB - 190 views
[2022-02-03 19:28:53]
Any possibility to comment further?
Here is another example test code, nothing complicated, short calculation/recalculation time - consistently ~1ms.
However, add two more copies of the study to simulate different studies using ACS drawings, recalculation time consistently >300ms (per study).
How can I determine the reason, when it must be happening outside of the study code?
SCSFExport scsf_ChartDrawingTest(SCStudyInterfaceRef sc)
  auto& in_MaxDrawings = sc.Input[0];
  auto& in_DrawingFrequency = sc.Input[1];
  if (sc.SetDefaults)
    sc.GraphName = "ACS Chart Drawing Test";
    sc.GraphRegion = 0;
    sc.AutoLoop = 0;
    sc.ValueFormat = VALUEFORMAT_INHERITED;
    sc.GlobalDisplayStudySubgraphsNameAndValue = 0;
    sc.DisplayStudyInputValues = 0;
    sc.HideDLLAndFunctionNames = 1;
    in_MaxDrawings.Name = "Max Drawing Count";
    in_MaxDrawings.SetInt(1000);
    in_MaxDrawings.SetIntLimits(1, 50000);
    in_DrawingFrequency.Name = "Bars Between Drawings";
    in_DrawingFrequency.SetInt(10);
    in_DrawingFrequency.SetIntLimits(5, 50);
    return;
  for (auto barIndex = sc.UpdateStartIndex; barIndex < sc.ArraySize; barIndex++)
    if (barIndex % in_DrawingFrequency.GetInt() != 0 || sc.HideStudy)
      continue;
    if (sc.GetACSDrawingsCount(sc.ChartNumber, 1) >= in_MaxDrawings.GetInt())
      break;
    if (sc.GetBarHasClosedStatus(barIndex) == BHCS_BAR_HAS_CLOSED)
      auto rectangle = s_UseTool();
      rectangle.ChartNumber = sc.ChartNumber;
      rectangle.Region = sc.GraphRegion;
      rectangle.AddMethod = UTAM_ADD_ALWAYS;
      rectangle.BeginValue = sc.Low[barIndex];
      rectangle.EndValue = sc.High[barIndex];
      rectangle.BeginIndex = barIndex;
      rectangle.EndIndex = barIndex + 10;
      rectangle.DrawUnderneathMainGraph = sc.DrawStudyUnderneathMainPriceGraph;
      rectangle.DrawingType = DRAWING_RECTANGLEHIGHLIGHT;
      rectangle.Color = COLOR_BLUE;
      rectangle.SecondaryColor = COLOR_RED;
      rectangle.LineStyle = LINESTYLE_SOLID;
      rectangle.LineWidth = 1;
      rectangle.TransparencyLevel = sc.TransparencyLevel;
      sc.UseTool(rectangle);
  if (sc.UpdateStartIndex == 0)
    const auto hidden = sc.HideStudy ? "Hidden" : "Visible";
    auto msg = SCString();
    msg.AppendFormat("Study ID: %d is %s | ", sc.StudyGraphInstanceID, hidden);
    msg.AppendFormat("Drawings Added by Study: %d | ", sc.GetACSDrawingsCount(sc.ChartNumber, 1));
    msg.AppendFormat("Total Drawings for All Studies: %d | ", sc.GetACSDrawingsCount(sc.ChartNumber, 0));
    msg.AppendFormat("Last Calculation Time: %d", sc.LastFullCalculationTimeInMicroseconds);
    sc.AddMessageToLog(msg, 1);
