Date/Time: Thu, 06 Mar 2025 09:57:44 +0000
Study Settings Period_OHLC-Variable_Period, Skip one period forward.
View Count: 459
[2022-01-29 16:41:44]
User14953 - Posts: 243
Is it possible for the lines displayed to be Skipped or extended one additional period forward?
I want to use this feature on an intraday chart to display lines for OHLC FROM the "previous time period" (Day), TO the time period TWO time periods (Days) Forward *Instead-of or *Additional-to the default displayed OHLC lines ONE time period Forward.
The OHLC lines for (mm/dd) date xx/04 are wanted to appear on date xx/06.
The OHLC lines for (mm/dd) date xx/05 are wanted to appear on date xx/07.
In consideration of the weekend, (Auto Skip Period of No Trading is set to Yes), then
The OHLC lines for (mm/dd) date xx/06 are wanted to appear on date xx/10.
Possible? Thank You
Previous/Period OHLC-Variable Period
[2022-01-31 16:19:34]
John - SC Support - Posts: 38425
The only way to do what you want would be to use the Spreadsheet Study and make an Absolute Reference to the data.
