Date/Time: Sun, 21 Jun 2026 19:53:18 +0000
[Programming Help] - How to create my own class and use it correctly?
View Count: 894
[2022-01-29 15:06:22]
Diego - Posts: 3
I test these:
in "Waves.h"
class SmallWaves
  public:
    SmallWaves();
    ~SmallWaves();
    void test();
SmallWaves::SmallWaves()
SmallWaves::~SmallWaves()
void SmallWaves::test()
  float temp = 0;
and in "Wave.cpp"
#include "Waves.h"
#include "sierrachart.h"
SCDLLName("My Studies")
SCSFExport scsf_TemplateFunction(SCStudyInterfaceRef sc)
  SCSubgraphRef SmallWavesTop = sc.Subgraph[0];
  SCSubgraphRef SmallWavesBottom = sc.Subgraph[1];
  SCFloatArrayRef Open = sc.BaseData[SC_OPEN];
  SCFloatArrayRef Close = sc.BaseData[SC_LAST];
  SCFloatArrayRef High = sc.BaseData[SC_HIGH];
  SCFloatArrayRef Low = sc.BaseData[SC_LOW];
  // Section 1 - Set the configuration variables and defaults
  if (sc.SetDefaults)
    sc.GraphName = "威科夫波浪";
    sc.AutoLoop = 1; //Automatic looping is enabled.
    SmallWavesTop.Name = "上升浪";
    SmallWavesTop.DrawStyle = DRAWSTYLE_TRANSPARENT_FILL_RECTANGLE_TOP;
    SmallWavesTop.PrimaryColor = RGB (50, 91, 212);
    SmallWavesBottom.Name = "下降浪";
    SmallWavesBottom.DrawStyle = DRAWSTYLE_TRANSPARENT_FILL_RECTANGLE_BOTTOM;
    SmallWavesBottom.PrimaryColor = RGB (255, 0, 255);
    //sc.Input[0].Name = "Float Input";
    //sc.Input[0].SetFloat(0.0f);
    return;
  SmallWaves wave();
  wave.test();
The bugs are:
Wave.cpp: In function 'void scsf_TemplateFunction(SCStudyInterfaceRef)':
Wave.cpp:35:7: error: request for member 'test' in 'wave', which is of non-class type 'SmallWaves()'
35 | wave.test();
[2022-01-29 23:25:39]
Tony - Posts: 717
我不是程序员,刚刚用ACSIL两年,没有办法回答你关于Class的问题,只是说说你代码里其他比较
明显的问题:
背景:ACSIL最基本的概念就是所有的K线作为数组来处理,比如你有100条K线,那么数组的编号就是
从[0]到[99],最后一条K线的编号可以用 sc.Index来代替,具体到我们这个例子,sc.Index的数
值就是99,如果有新的K线(比如5分钟图的下一个5分钟)那sc.Index的数值会自动跟新,就是100,
101..依次排下去。开盘价、收盘价、最高价和最低价不需要专门定义,直接调用就可以,比如,如果
你想知道第67根K线的最高价:sc.High[67],或者最后一条K线的收盘价:sc.Close[sc.Index]。
有了背景知识,你要添加的任何指标,实际上就是在已有的K线数组上添加新的数组而已,编号一样,具
体到你的代码里,从 SmallWavesTop[0] 到 SmallWavesTop[sc.Index],以及从 SmallWavesBottom[0]
到 SmallWavesBottom[sc.Index]都要有数据,不然就算编译通过了,你在图上也看不到任何结果。
威科夫波浪有很强的主观性,如果没有具体的公式,很难在K线图上表达出来。
DRAWSTYLE_TRANSPARENT_FILL_RECTANGLE_TOP 和 DRAWSTYLE_TRANSPARENT_FILL_RECTANGLE_BOTTOM
是作为一对数据来用的,用来显示一条信息。你的代码里好像有两条信息:上升浪和下降浪,应该需要两对
上下对应的 DRAWSTYLE 才对。
另外,根据我的经验,用function可能比用class要方便,而且放在同一个.cpp文件即可,如果有
其他指标,也都可以放在同一个.cpp文件。
Date Time Of Last Edit: 2022-01-29 23:54:39
[2022-01-30 01:07:25]
Diego - Posts: 3
明显的问题:
哇塞,竟然有同胞,你提到的前边的几个问题我都清楚,K线序列、高开低收、配对DRAWSTYLE。我使用class的原因是必须要使用面向对象,因为我之前在MT4里面写的缠论的笔段指标是通过周期递归实现的,如果改成面向过程的话会有大量重复代码,可能会到几千行,非常的麻烦。使用class只需要500行就可以了。
[2022-01-30 01:14:52]
Diego - Posts: 3
The bug has been solved,change
SmallWaves wave();
to
SmallWaves wave;
