Date/Time: Thu, 06 Mar 2025 09:11:11 +0000
Intraday Weekly Chart Data Error
View Count: 507
[2022-01-29 14:51:26]
THANOS929 - Posts: 23
There appears to be some setting that I am missing in the aggregation or starting dates.
I am having a difficult time showing ESH22-CME properly on a intraday weekly time frame. This also happens with other CME symbols such as the YM and NQ. This should look like the spx index weekly chart. The chart is set for intraday only and on a weekly time frame. When comparing it to the historical weekly chart, I understand the differences of the overnight time frame but something is just not correct.
The intraday weekly starting dates appear to be off for some reason. On the historical, for the last week it start on the 24th and on the intraday weekly it starts on the 26th. When visually looking at the charts they are completely different. Can the 17th of January have something to do with the weekly aggregation?
Thanks,
https://www.sierrachart.com/image.php?Image=164346756927.png
https://www.sierrachart.com/image.php?Image=1643467973552.png
Date Time Of Last Edit: 2022-01-29 14:53:00
imageintraday chart settings.PNG / V - Attached On 2022-01-29 14:47:47 UTC - Size: 48.18 KB - 155 views
imageweekly INX.PNG / V - Attached On 2022-01-29 14:47:52 UTC - Size: 72.33 KB - 148 views
[2022-01-29 19:04:49]
Refer to the documentation here for this:
Chart Settings: Days-Minutes-Seconds-Milliseconds Per Bar (Chart >> Chart Settings >> Bar Period >> Intraday Chart Bar Period Settings menu)
Specifically:
To have Weekly bars start on a Sunday it is necessary to set Chart >> Chart Settings >> Use Date Range >> From to a Sunday Date in the past.
