Date/Time: Thu, 06 Mar 2025 08:50:48 +0000
1 day of full use...
View Count: 637
[2022-01-29 10:11:01] |
User814744 - Posts: 1 |
Just registered the trial period, after 1-st login have a message that I have only 1 day of full usage instead 15 days. Is it normally?
[2022-01-29 14:50:57] |
MarkTekk - Posts: 6 |
I think what you'r looking for is here: Sierra Chart Trial Account
[2022-01-29 15:58:41] |
Yes go through the activation procedure here: Sierra Chart Trial Account Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
